NTSB Issues Final Report On Southwest 1380 Accident
Photo: Southwest Airlines
  • The NTSB's final report on Southwest Flight 1380 concluded that a piece of the engine cowling, not the failed fan blade itself, penetrated the fuselage, causing the cabin depressurization and fatality.
  • The probable cause was a low-cycle fatigue crack in a fan blade that went undetected by the previously required fluorescent penetrant inspection (FPI); a more sensitive eddy current inspection (ECI) was later developed.
  • The NTSB called for Boeing to redesign the 737 Next Generation's fan cowl structure to better withstand fan blade impacts and to implement these changes on both new and existing aircraft.
The NTSB has published the final report on Southwest Flight 1380, whose left-side CMF56 engine suffered a failure that led to one fatality in April 2018. While the NTSB has already called for action following the engine on this 737 Next Generation, its final report closes the investigation and emphasizes how it was a piece of the cowling, and not the failed first-stage fan blade, that penetrated the fuselage.
In its analysis, it says the board determined “the probable cause of this accident was a low-cycle fatigue crack in the dovetail of fan blade No. 13, which resulted in the fan blade separating in flight and impacting the engine fan case at a location that was critical to the structural integrity and performance of the fan cowl structure. This impact led to the in-flight separation of fan cowl components, including the inboard fan cowl aft latch keeper, which struck the fuselage near a cabin window and caused the window to depart from the airplane, the cabin to rapidly depressurize, and the passenger fatality.”
As for the fan blade and the associated inspection process itself, the NTSB said that “metallurgical examinations of the fractured fan blade found that the crack had likely initiated before the fan blade set’s last overhaul in October 2012. At that time, the overhaul process included a fluorescent penetrant inspection (FPI) to detect cracks; however, the crack was not detected for unknown reasons. After an August 2016 FBO event involving another SWA 737-700 airplane equipped with CFM56-7B engines, which landed safely at Pensacola International Airport, Pensacola, Florida, CFM developed an eddy current inspection (ECI) procedure to be performed at overhaul (in addition to the FPI that was already required). An ECI has a higher sensitivity than an FPI and can detect cracks at or near the surface (unlike an FPI, which can only detect surface cracks).”
Prior to publishing this final report, the NTSB called for Boeing to determine the critical fan-blade impact locations on the fan cowl and redesign it to better handle a blade separation and to push those changes to all new 737 Next Generation aircraft as well as retrofitting all aircraft in the field.
mcook
