“Depart” is test pilot slang for “Departure from controlled flight.” It can refer to something as mild as a wing drop during a stall to a high-altitude “upset” that results in the airplane literally falling out of the sky.
Virtually all engines have some mechanism or device to enrich the mixture at high power settings for cooling by excess fuel. On most GA engines, it’s a device that simply enriches the mixture when the throttle is mechanically in the full open position. Any reduction from that position will cause EGT and CHT to soar, unless it’s a very large reduction, perhaps five inches of manifold pressure or so.
This is not as hard on the engines as many think. One common mistake is the classic reduction after takeoff to 25″ manifold pressure, and about 2500 RPM. The new electronic engine monitors are now telling us this the probably a major mistake, as cylinder head temperatures just soar on most flat fours and sixes, due to leaning. Most of these engines have “enrichment” feature for adding extra fuel to the mixture for cooling when the throttles are fully open (non-charged engines), or when the manifold pressure is at takeoff power (charged engines). The engine runs FAR cooler at takeoff power. This also applies to single-engine aircraft.
METO is an old term for “Maximum Except Take Off” power, or the highest power that can be maintained continuously. In the big recips, Takeoff Power is generally limited to two minutes.
What’s a “decent altitude”? Pick one for yourself, but probably TPA (Traffic Pattern Altitude), or above.
An abrupt aerobatic maneuver in which the stick is snapped back hard to the stop, and full rudder is applied, from some speed well above the normal stalling speed. It is literally a horizontal spin, entered from an accelerated stall.
We use “turbojet” as a generic term for any jet engine, not including those with props. Those with props are called “turboprops.”
FAR 1.2 Abbreviations and symbols
VMC means minimum control speed with the critical engine inoperative.
FAR 23.149 Minimum control speed.
(a) VMC is the calibrated airspeed at which, when the critical engine is suddenly made inoperative, it is possible to maintain control of the airplane with that engine still inoperative, and thereafter maintain straight flight at the same speed with an angle of bank of not more than 5 degrees. The method used to simulate critical engine failure must represent the most critical mode of powerplant failure expected in service with respect to controllability.
(b) VMC for takeoff must not exceed 1.2 VS1, where VS1 is determined at the maximum takeoff weight. VMC must be determined with the most unfavorable weight and center of gravity position and with the airplane airborne and the ground effect negligible, for the takeoff configuration(s) with –
(1) Maximum available takeoff power initially on each engine;
(2) The airplane trimmed for takeoff;
(3) Flaps in the takeoff position(s);
(4) Landing gear retracted; and
(5) All propeller controls in the recommended takeoff position throughout.
(c) For all airplanes except reciprocating engine powered airplanes of 6,000 pounds or less maximum weight, the conditions of paragraph (a) of this section must also be met for the landing configuration with –
(2) The airplane trimmed for an approach, with all engines operating, at VREF, at an approach gradient equal to the steepest used in the landing distance demonstration of 23.75;
(3) Flaps in the landing position;
(4) Landing gear extended; and
(5) All propeller controls in the position recommended for approach with all engines operating.
(d) A minimum speed to intentionally render the critical engine inoperative must be established and designated as the safe, intentional, one engine inoperative speed, VSSE.
(e) At VMC, the rudder pedal force required to maintain control must not exceed 150 pounds and it must not be necessary to reduce power of the operative engine(s). During the maneuver, the airplane must not assume any dangerous attitude and it must be possible to prevent a heading change of more than 20 degrees.
(f) At the option of the applicant, to comply with the requirements of 23.51(c)(1), VMCG may be determined. VMCG is the minimum control speed on the ground, and is the calibrated airspeed during the takeoff run at which, when the critical engine is suddenly made inoperative, it is possible to maintain control of the airplane using the rudder control alone (without the use of nosewheel steering), as limited by 150 pounds of force, and using the lateral control to the extent of keeping the wings level to enable the takeoff to be safely continued. In the determination of VMCG, assuming that the path of the airplane accelerating with all engines operating is along the centerline of the runway, its path from the point at which the critical engine is made inoperative to the point at which recovery to a direction parallel to the centerline is completed may not deviate more than 30 feet laterally from the centerline at any point. VMCG must be established with –
(1) The airplane in each takeoff configuration or, at the option of the applicant, in the most critical takeoff configuration;
(2) Maximum available takeoff power on the operating engines;
(3) The most unfavorable center of gravity;
(4) The airplane trimmed for takeoff; and
(5) The most unfavorable weight in the range of takeoff weights.
FAR 25.149 Minimum control speed.
(a) In establishing the minimum control speeds required by this section, the method used to simulate critical engine failure must represent the most critical mode of powerplant failure with respect to controllability expected in service.
(b) VMC is the calibrated airspeed at which, when the critical engine is suddenly made inoperative, it is possible to maintain control of the airplane with that engine still inoperative and maintain straight flight with an angle of bank of not more than 5 degrees.
(c) VMC may not exceed 1.2 VS with –
(1) Maximum available takeoff power or thrust on the engines;
(2) The most unfavorable center of gravity;
(3) The airplane trimmed for takeoff;
(4) The maximum sea level takeoff weight (or any lesser weight necessary to show VMC);
(5) The airplane in the most critical takeoff configuration existing along the flight path after the airplane becomes airborne, except with the landing gear retracted;
(6) The airplane airborne and the ground effect negligible; and
(7) If applicable, the propeller of the inoperative engine –
(i) Windmilling;
(ii) In the most probable position for the specific design of the propeller control; or
(iii) Feathered, if the airplane has an automatic feathering device acceptable for showing compliance with the climb requirements of 25.121.
(d) The rudder forces required to maintain control at VMC may not exceed 150 pounds nor may it be necessary to reduce power or thrust of the operative engines. During recovery, the airplane may not assume any dangerous attitude or require exceptional piloting skill, alertness, or strength to prevent a heading change of more than 20 degrees.
(e) VMCG, the minimum control speed on the ground is the calibrated airspeed during the takeoff run at which, when the critical engine is suddenly made inoperative, it is possible to maintain control of the airplane using the rudder control alone (without the use of nosewheel steering), as limited by 150 pounds of force, and the lateral control to the extent of keeping the wings level to enable the takeoff to be safely continued using normal piloting skill. In the determination of VMCG, assuming that the path of the airplane accelerating with all engines operating is along the centerline of the runway, its path from the point at which the critical engine is made inoperative to the point at which recovery to a direction parallel to the centerline is completed may not deviate more than 30 feet laterally from the centerline at any point. VMCG must be established with –
(2) Maximum available takeoff power or thrust on the operating engines;
(f) VMCL, the minimum control speed during approach and landing with all engines operating, is the calibrated airspeed at which, when the critical engine is suddenly made inoperative, it is possible to maintain control of the airplane with that engine still inoperative, and maintain straight flight with an angle of bank of not more than 5 degrees. VMCL must be established with –
(1) The airplane in the most critical configuration (or, at the option of the applicant, each configuration) for approach and landing with all engines operating;
(3) The airplane trimmed for approach with all engines operating;
(4) The most favorable weight, or, at the option of the applicant, as a function of weight;
(5) For propeller airplanes, the propeller of the inoperative engine in the position it achieves without pilot action, assuming the engine fails while at the power or thrust necessary to maintain a three degree approach path angle; and
(6) Go-around power or thrust setting on the operating engine(s).
(g) For airplanes with three or more engines, VMCL-2, the minimum control speed during approach and landing with one critical engine inoperative, is the calibrated airspeed at which, when a second critical engine is suddenly made inoperative, it is possible to maintain control of the airplane with both engines still inoperative, and maintain straight flight with an angle of bank of not more than 5 degrees. VMCL-2 must be established with –
(1) The airplane in the most critical configuration (or, at the option of the applicant, each configuration) for approach and landing with one critical engine inoperative;
(3) The airplane trimmed for approach with one critical engine inoperative;
(4) The most unfavorable weight, or, at the option of the applicant, as a function of weight;
(5) For propeller airplanes, the propeller of the more critical inoperative engine in the position it achieves without pilot action, assuming the engine fails while at the power or thrust necessary to maintain a three degree approach path angle, and the propeller of the other inoperative engine feathered;
(6) The power or thrust on the operating engine(s) necessary to maintain an approach path angle of three degrees when one critical engine is inoperative; and
(7) The power or thrust on the operating engine(s) rapidly changed, immediately after the second critical engine is made inoperative, from the power or thrust prescribed in paragraph (g)(6) of this section to –
(i) Minimum power or thrust; and
(ii) Go-around power or thrust setting.
(h) In demonstrations of VMCL and VMCL-2 –
(1) The rudder force may not exceed 150 pounds;
(2) The airplane may not exhibit hazardous flight characteristics or require exceptional piloting skill, alertness, or strength;
(3) Lateral control must be sufficient to roll the airplane, from an initial condition of steady flight, through an angle of 20 degrees in the direction necessary to initiate a turn away from the inoperative engine(s), in not more than 5 seconds; and
(4) For propeller airplanes, hazardous flight characteristics must not be exhibited due to any propeller position achieved when the engine fails or during any likely subsequent movements of the engine or propeller controls.
