Prepping For Your IPC
Maintaining your IFR currency isnt that hard. Just fly and log in actual or simulated conditions six instrument approaches, holding procedures and tasks and intercepting and tracking electronic courses within the preceding six months, and youre golden. But after 12 full months of being out of IFR currency, youll need an instrument proficiency check, or IPC. There was a time, before the most recent revisions to FAR 61, when an IPC-previously known as an instrument competency check- wasnt structured. Thats no longer the case.
Maintaining your IFR currency isnt that hard. Just fly and log in actual or simulated conditions six instrument approaches, holding procedures and tasks and intercepting and tracking electronic courses within the preceding six months, and youre golden. Even if you find yourself slightly out of currency in the 11th month, you can go out with a safety pilot and fly the requisite approaches/holds/intercepts, regaining your ability to legally file and fly IFR.
But after 12 full months of being out of IFR currency, youll need an instrument proficiency check, or IPC. There was a time, before the most recent revisions to FAR 61, when an IPC-previously known as an instrument competency check- wasnt structured. Thats no longer the case. The instrument proficiency check must consist of the areas of operation and instrument tasks required in the instrument rating practical test standards.. So sayeth FAR 61.57. Essentially, youre taking what could turn out to be another instrument rating checkride. How will you prepare?
Step One
As with a 12-step program, the first thing you should do is admit you have a problem. Getting back into the IFR saddle isnt the end of the world, but its not as easy as it once was, either. To do this right, youll need to spend some time studying and you might even need some practice before going for the actual IPC. Then youll need to seek out an instrument instructor whos willing to give you the IPC.
Depending on your situation- how many of your buddies have their double-I and whether the willing instructor knows you and how you fly, for example-you mightget off easy. The other extreme? If you rent and the FBO looks at IPCs as a profit center, good luck. As the FAAs Instrument Proficiency Check Guidance handbook (IPC Guide) states, an IPC more often requires short-term evaluation of an unknown pilot, possibly with the added challenge of an unfamiliar aircraft and/or avionics.
As always when someone is gearing up for a new rating, a flight review or even a simple endorsement, wed encourage trying to make it as much of a learning experience as possible. For the IPC, that might mean getting a high-performance or complex endorsement at the same time, or maybe working in a flight review sign-off (which should be a no-brainer). That said, we wouldnt advise doing your IPC in something equipped with a Garmin G1000 panel if all youve flown before are steam gauges.
Guidance
While some of the foregoing might not brighten your day, heres something that could: The aforementioned IPC Guide is a comprehensive overview of the IPC and everything you need to know, laid out in a logical fashion. Wed encourage anyone who needs or may need an IPC to download a copy in the PDF format from the FAAs Web site: tinyurl.com/avsafe-ipc. While youre at it, you also should grab a copy of the instrument ratings practical test standards (PTS), also in PDF: tinyurl.com/ avsafe-ifrpts.
Additional guidance is available on the FAAs FAASTeam Web site, www.faasafety.gov, including both commercial and FAA-sponsored courses designed just for you: the pilot who needs an IPC. At least the one course we previewed for this article isnt an in-depth review. It does, however, hit the high spots and will help you recall some of the basic numbers and rules applicable to instrument flying.
A final word of advice before tackling some other topics: Dont show up for your IPC without current charts. Nothing screams unprepared like pulling out a book of terminal procedures that expired before the last time you were current. Be sure youre carrying current approach plates and en route charts for the area in which youre flying and at least some kind of separate reference listing airport data, like is found in the FAAs Airport/Facility Directory, the green books. If youre using an electronic tablet like an iPad for your charting, be sure your EFB soft- ware is up-to-date and the application has current chart data. It also would be helpful if you actually knew how to use the application and had some method of mounting the thing where you can refer to it easily while flying an approach. Its considered really bad form if you have to ask the double-I to hold your iPad while verifying the inbound course or minimum altitude youre supposed to be flying.
The Plan
Why two? One of the compleat instrument pilots dirty little secrets is the alternate airport filed on the flight plan probably isnt the alternate shell use in a pinch. For one thing, its unusual-not unheard of, but unusual-for the original destination to go so far down the tubes we cant get in. The legal alternate is just that: The one we can actually reach after flying to our destination and failing to get in, given the fuel available and distances involved.
Your real alternate easily could be some other facility, one sitting astride your flight-planned route, for example, or the smaller facility thats downwind from your filed alternate. If youve got the gas, your alternate could even be your departure point. And unless youre confronting some really scuzzy and fast-moving weather not complying with your briefing, theres usually plenty of warning conditions are low enough youre not going to be able to land at your destination. But only a sadistic double-I with a death wish would launch on an IPC in that kind of weather, right?
Things to Consider
Ideally, you and your double-I will have discussed how he intends to conduct the IPC before you show up for it. This could include such details as the destination for which he or she expects you to plan a flight, the aircrafts equipment and how youre expected to use it. Given the FAAs recent and long-overdue emphases on risk management, you also should expect some qualitative assessment of how you view and respond to weather and equipment-failure scenarios.
Another thing you might expect to be asked is to explain the delay between a Nexrad image being captured, processed, transmitted and appearing on your in-cockpit display. Its called latency, and might be as much as 20 minutes. A thunderstorm can move several miles in that time, and weve witnessed them blossom from yellow to colors weve never seen before in less.
Flying the Plane
Up to now, we havent even touched on the key thing on which youre going to be evaluated: Flying solely by reference to instruments. If its been a couple of years since you were IFR current, you likely need some practice before showing up for your IPC. There are a number of ways to skin this cat: One of the simplest might be to get some instrument dual with the double-I with whom you plan to do the IPC. That way, at least you can polish up on the stuff he or she considers important. One of the least-expensive and most-rewarding might be to get some time in an approved simulator or flight training device. In our experience, theyre much harder to fly well than the actual airplane, and youre likely to learn a few things along the way to perfect your scan and refresh your procedures.
By this time, youve probably figured out that maintaining your IFR currency once you regain it will be easier than getting an IPC every year or so. Work with your double-I to schedule some post-IPC instrument flying so you wont find yourself in this bind again.
This article originally appeared in the July 2013 issue of Aviation Safety magazine.
